TwinTurbo.NET: Nissan 300ZX forum - Agree with CmyZ, pump is probably a remanufactured
ttz'in (norcal)
on September 22, 2015 at 11:11 AM
Re: Bad bearing overtigthening it can be the problem. If
posted by Diplomat1
on September 22, 2015 at 09:55 AM
unit. OEM pumps seem to work best.
Over flow hose problem was due to belt coming off and pump not circulating coolant thru radiator. Pressure then went to high and found the easiest way out.
Very weird Water pump problem
Diplomat1
22:02:23 09/20/15
jambed pump bearing. Is that a rebuilt, remanufactured or>>
ZUL8TR
04:39:25 09/21/15
Re: jambed pump bearing. Is that a rebuilt, remanufactured or>>
Diplomat1
10:45:41 09/21/15
Wonder if also there was something blocking/clogging the
jzack
11:02:26 09/21/15
Re: Wonder if also there was something blocking/clogging the
Diplomat1
11:40:02 09/21/15
CmyZ
21:33:09 09/21/15
Diplomat1
09:55:14 09/22/15
Agree with CmyZ, pump is probably a remanufactured -
ttz'in (norcal)
11:11:22 09/22/15
Re: Agree with CmyZ, pump is probably a remanufactured
Diplomat1
12:11:28 09/22/15
There are differences between OEM and aftermarket pumps
xpwarrior
13:17:18 09/22/15
I'll give you the Short Version of my WP Story..
Cjw3
20:52:11 09/23/15
Tough call without "feeling" it. Less than 75K miles?
ttz'in (norcal)
14:04:55 09/22/15
